Old 06-27-2010, 11:26 PM   #4 (permalink)
Frank Lee
I've done a fan delete and grille block, along with engine blanket, and my 5.0 will occasionally hit 20. I think using P- series tires instead of LT- helps. On mine I've found going oversize kills fe. Stock is 235/75R15; it wears 245/75s now; it's had bigger in the past but I won't do that again. The E4OD doesn't like that and upshifts outta OD too much. Forget that hood thing unless you like the idea of the styling change. The airdam idea might have merit. These things are gonna push lots of air no matter what unless you get radical, so the big thing is to keep it under 60 mph.
