zapped control board
the 12volt leads are not providing power in either orientation. I have hooked them up and can get meter readings thru the big resistor R1 and the first diode D1.
after that i'm not sure where to check the voltage.
but i know i can get power into the board at least passed those components.
any others i should start lookin at?
i am suspicious of the cimcon, there are no voltage readings on any part of the board passed that component.
