Old 06-29-2010, 05:48 PM   #3512 (permalink)
Darxus
Darxus's Avatar
Originally Posted by LUCKY13 View Post
Is it possible to modify them to handle higher amperage? Up to 120a?
How many volts?
Horrible circuit diagram attached. Red = battery on, blue = battery off. Tell drivers to frequently switch off whichever battery is hottest. Keep in mind switch failure mode = welding shut (on). Larger switch contact area (bigger chunk of metal) = lower energy density = less likely to weld. Include an emergency disconnect switch. Copper is good.
I recommend making your own double-throw knife (Frankenstein) switches.
(Photo from Basic Concepts Of Electricity )
ID:	6263   Click image for larger version
