Old 06-30-2010, 03:52 AM   #194 (permalink)
DamageX
Does it use a distributor with mechanical/vacuum advance? Advance curves can be out-of-whack on those when they are old, although misfire can also be a fuel issue. All the more reason to convert to megasquirt/EDIS am I right? Will, we should meet up so I can check out your car sometime.
Also, Front-hinged hoods FTW.
