Old 04-06-2008, 10:50 AM   #11 (permalink)
lovemysan
lovemysan's Avatar
gutless wonder - '02 Saturn sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 chevy surburban 2wd LT
90 day: 19.43 mpg (US)
That fans blade is designed to suck. I removed the clutch fan from a friends 2.8 s10. I installed a thermal switch behind the radiator to run the fan. It did not work very well. It either overheated or ran too often. For an E fan system to work properly you need to run the fan using a water temp sensor installed on the intake. Something like this should work.
http://store.summitracing.com/partde...5&autoview=sku
You could probably source your parts off of a cavalier or sunfire, considering they have the same engine & a factory efan.
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
