Old 06-30-2010, 11:08 PM   #3 (permalink)
wyatt
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Originally Posted by Old Tele man View Post
...I was sorta inferring to OP number of decimal places...randomness in readings plays havoc with precise numbers...never try to measure & use more decimal places than absolutely necessary, nor more than you really know to be accurate.
If you are an engineer, that is one you learn the hard way.
If your odometer says 10.8 you know 3 decimal places. You may be able to read between the lines some, and guess to the next half, but in my car the "tenths" place is not smooth, but tends to jump at the end of that tenth of a mile. Which puts a +/- on the readings. 10.8 miles isn't a long ways. I calibrated my car over 70.0 miles (mile markers that were down to the tenth of a mile) vs my odometer, and the tenths place jumped as I passed 70.0 miles. I also did a comparison with GPS over 200 continuous miles, and Google Maps over 400+ miles. All of them showed between 5.9% and 6% off, so for ease of math, I just use 6%. Just think, if your odometer doesn't click the last tenth of a mile, you are off by 1% at 10.0 miles, over 100.0 miles it's only 0.1%.
