Old 06-30-2010, 11:59 PM   #14 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
DFCO in a 1994 Suzuki swift 1.3
blue is injector signal
in the image above
in the upper left is the screen this image was culled from , note the gap in the blue trace .
that gap is DFCO , there was no injector signal from the ECM during the gap .
i captured this by snapping the throttle to WOT then releasing it , allowing the engine to slow down from the speed it reached during the WOT snap , as soon as the TPS shows closed throttle and rpm is hi
the ECM shuts off fuel , the ECM starts fuel back up when it sees rpm falling below the value it was programmed to restart fuel at .
all newer cars have DFCO .
if your car does not Have functioning DFCO , the first thing to check is the TPS or closed throttle switch , because if the ECM does not know the throttle is closed , it will not activate DFCO
