Old 07-01-2010, 09:51 AM   #29 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
the alternators fitted to the e30 have a sort of fanblade/waterwheel setup on the pulley driven by the belt-could that be modded to produce something similar to the hole solution you've suggested?
Essentially then you just need to get the steam to drive the alt.
Also what consideration haave you given to rusting to the exhaust?
Its a great idea, but what effect will the additional sleeve on drag under the car if it hangs lower than the rest of the exhaust, or do you envisage using the setup on the downpipe or manifold?
