Old 07-01-2010, 02:55 PM   #42 (permalink)
Daox
Originally Posted by Patrick View Post
Air tool vanes are a plastic composite. They are cooled by the expansion of the compressed air and you have to add lubricating oil periodically or they will seize up. The tools also run at very high rpms, so some sort of gearbox would probably be needed.
I'll have to take apart the die grinder I have to see what materials are in it. I'll post pics when I do.
You are correct though, most grinder's rpm is way higher than what an alternator will handle. I suspect once you put the loaded alternator on the grinder you'll drop those rpms to a reasonable level though. Hopefully no reduction is needed. To be honest, I'm more worried about getting enough pressure to keep up with the grinder at this point.
