Originally Posted by discovery
Second question How long does it take to charge/discharge each stick untill it stops improving?
It depends on the discharge/charge rate. IIRC I used 2 Ahr, and one stick takes about 3 hours to complete a cycle.
Also can you post any pic's showing what you mean by hooking up across each stick?
Don't have pictures handy, but the Insight pack is 20 sticks held in a frame. You need to pull covers off each end (one has some electronics and is bolted, the other's just a plastic shield. Then you can see the contacts for each stick, which are bolted in with (IIRC)10 mm bolts. Undo those (a cordless drill/driver is a BIG help here), again making sure to wear insulating gloves & take other precautions against shock.
Some of the bolts have fairly thick spacers (like a washer about 1/2 inch thick) under them. Make up a couple of leads for the charger that end in ring terminals that fit the bolts, and screw the leads in to each stick in turn. Note that they alternate polarity: if one end of the first is +, the next will be -.
So far sounds easy and cheap?
Not difficult once you get the hang of it, but time-consuming. Takes me about 4-5 days to do the whole pack.
I'm sorry for the too many questions, but where
do you get new batt sticks?
AFAIK you can't get new ones. Your best bet is to find someone who has a second pack gotten from a wrecked vehicle. But often, just re-balancing a pack with a discharge/charge cycle on each stick is enough to make it serviceable again.
Note that the sticks on later Civic Hybrids are different, with 12 D cells bonded into a unit, rather than sticks of 6.
