Old 07-01-2010, 07:49 PM   #45 (permalink)
Daox
Well, I tried the die grinder powering the alternator tonight. It was quick and easy to do. I just put a 10mm socket adapter in the die grinder. The alternator has a 10mm hex on the end of it.
I tested at 50, 75 and max (120ish) psi. Here is the result at max psi.
The Following 3 Users Say Thank You to Daox For This Useful Post:
Christ (07-02-2010), RobertSmalls (07-01-2010), Weather Spotter (07-06-2010)
