Yes, it reports a fuel usage of ~2.5 l/100km at ~80 kmh (that's ~94 MPG at ~50 MPH).
From what I've heard, the fuel usage is calculated from air flow to the engine, so SGII will show a fuel usage even if the injectors are off, as long as it does not assume DFCO (from open loop and throttle closed). Is this correct, or have I misunderstood something?
