Old 07-03-2010, 07:06 AM   #6 (permalink)
Laurentiu
Hypermiling rookie
Laurentiu's Avatar
Opel Corsa B - '96 Opel Corsa 1.2 8V
90 day: 47.27 mpg (US)
VW Bora 1.6 16V - '02 Volkswagen Bora/Jetta
90 day: 35.84 mpg (US)
Arrow
Originally Posted by Arragonis View Post
The FE thing is confusing. My 1.9 TDi makes less FE with 130 HP in a small hatchback than my wife's 2.0 TDi (with 16v mind) does in a Jetta sized estate.
Time to look more at that nut behind the wheel again I suppose.
You are comparing THIS engine with THIS engine, right ?
Well, first of all like you mention the 8v vs. 16v makes a difference straight away when it comes to efficiency as well as 5spd vs. 6spd (The Octavia has 6 speed transmission ?)
The weight/output ratio is practically identical but those differences as well as a Cx of 0.30 for the Octavia vs. 0.33 for the Fabia bring that extra FE capability.
I see also the stock tires on the Octavia are narrower (195/65 R15) vs. 205/45 R16
The factory numbers are pretty the same (5.5l/100km vs. 5.6l/100km) but the way they measure that is not by ecomodding...
BTW, what do you think of the new 1.6TDI's in the new Fabia's ? Pretty sweet FE rated at 4.2 combined (56MPG US) :drooling:
"It has been my observation that most people get ahead during the time that others waste" Henry Ford
