Originally Posted by ChopsQube
As for ecomodding, all I have done so far is bump my tire pressure up to max sidewall of 51psi (actually just over). I'm now running at 56psi up front and 53psi in the back.help.
How does that feel in a newer generation car, compared to stock pressures ?
When I put mine to 42 psi (back-front), it felt like it's going to just rattle itself to pieces, had to lower it to 36-38PSI, I guess if you drive mainly on highways and smooth roads it's ok
