After looking at them, I've decided that I'll give it a curve on the front instead of that sharp edge. However, I won't be able to take new pictures, since I had to sell the camera, and I'll have to wait until I have the car back to alter the skirts.
The car is also in the shop, since it recently wouldn't start due to a lack of spark. I replaced the ignition coil, distributor cap/rotor, and TFI module, but none of those were the problem. It's most likely the stator, but I asked the shop to make sure it's getting power to the coil and through the system to make sure (I don't have a volt meter or the knowledge to use it). Unfortunately, I won't be getting a clean test of the side skirts. As soon as it's done, I'll be heading down to California for a couple weeks. My goal is to only stop for gas once on this 650 mile trip, and I usually fill up the tank when it's 11 gallons under the F mark. The last 2 times I made this trip, I had to stop twice.
In Reason we Trust
