So I got my Logisystems Revolt hybrid up and running
Great use of the power stage considering there was nothing really wrong with it. I took the car out and everything is good, except for heat.
There is a fairly good heatsink installed on the LS power stage, except that its fins could be bigger. Other than actual physical alterations though is there a possibility of altering some of the PWM or other software parameters that would decrease the heat output?
If not then can someone suggest relatively easy thermal management solutions (read cheap)
thanks!!!
