does the LS power stage use mosfets or igbts? I suspect i read somewhere its igbts. If so your probably not driving them at full capacity with a stock control board. What gate resistors are you using? Also consider another resistor and fast recovery diode in inverse parallel to aid turn off.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
