Old 07-05-2010, 11:39 AM   #27 (permalink)
ShadeTreeMech
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Originally Posted by Nevyn View Post
I can report with near 100% certainty that my 2004 Elantra DOES, in fact, have some sort of DFCO. Kicks in at 2000 RPM, and out at 1200. I'll try to get video of it coming in and going out.
However, the SGII doesn't see it - I'm betting because it stays in closed loop as the computer "knows" it's going lean.
I wonder if I can program an Xgauge for my O2 sensor?
On my scanguage I can see the dfco kick in by the GPH reading (gallons per hour) because it will kick over to 0 fairly quickly when I let off the throttle. I suppose the o2 sensor would stay in closed loop if the ecu "knows" the o2 readings will go off the charts during dfco. Of course, the reaction of higher o2 readings is to spray more fuel, so if the injectors are cut off that can't exactly happen.
AFAIK there isn't a a/f ratio guage built in, I suppose it might be an xguage. I do know you can read up to 4 seperate banks of o2 sensors with the right xguage though.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
