Old 07-05-2010, 05:24 PM   #4 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Nuts. Thanks Comptiger. Guess I hit the wrong key...
Mike, yes, either a relay or a simple switch for me to hit to break the electrical circuit. My truck does not have the MDS (multi-displacement system-HEMIs only). This is my attempt to create a decel fuel cutoff like my 91 VW Jetta, 1990 Audi 100, and my wife's 08 Dodge Avenger have.
Well, my first attempt had limited success. I dug through the wiring diagrams and isolated the ground wire coming from all the injectors and spark plugs, going into a large connector (C130) near my truck's PCM. So I cut wire #4 and ran a pair of wires into the cab so I could flip a switch and open the circuit. Well, it seems to only work if I am coasting down a hill with the throttle closed. If I try it with the truck idling in the drive, it keeps idling; or coasting toward a stoplight on close to level ground, it keeps idling. I have only seen the fuel flow on the MPGuino go to 0.0 when coasting down the steeper hill (@45 mph, in 5th gear). Reasearch continues....
