Old 07-05-2010, 05:18 PM   #3529 (permalink)
voltmatic automaton
AHHH....so thats what you mean
ok, so i found your diagram for the circuit using an IGBT setup.
let me figure this correctly.
the way i have it now, the control board (revolt), i use one of the GR pads to run a line from the control board to the LS power stage. I did this because the Gate Resistors are in the power stage of the LS controller.
For the LS, there is a single pin that this line was soldered into.
If i go with the IGBTs, should i just make a small board to insert between the control and power stage so that it will produce the same signal effect?
Name:	my circuit.JPG
