- PCB software to do the schematic which then drives the layout of the board. There's some free ones out there.
- Laserprint artwork onto vellum to be used as a photopositive
- cut pre-sensitized PCB blank to size, remove the plastic film, put the artwork on top, sandwich it in a frame and expose the board through the artwork using a fluorescent lamp. Boards are pretty cheap. I bought 6" x 10" for I think $6 a board years ago that I'm still using.
- develop the board
- etch the unwanted copper off
- drill, then stuff.
Exposure has to be experimentally developed. My time is 14.5 mins.
Develop is ~ 5 seconds, or until emulsion clears fully
Etch is ~ 8 mins
Drilling is the biggest problem if you don't have the carbide bits on hand already.
Note that laserprinters are not exact in X and Y so long dimensions can walk off on you. My HP4100 is pretty good, my HP4+ I had before was worse.
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
