Old 07-06-2010, 06:48 PM   #10 (permalink)
aerohead
template
Originally Posted by Dr. Jerryrigger View Post
As the template was made for a flat bottom vehicle, it I was thinking that the additional curve on the underside would allow for a scaled-down curve (which would be quite helpful for this application on this short car).
The only parameter for the template is proper scaling of the subject vehicle image,such that the point of maximum roof camber ( typically just the high point of the roof ) matches that of the template when the bottom of the tires are along the same ground plane.
