Old 07-06-2010, 11:58 PM   #220 (permalink)
JellyBeanDriver
JellyBeanDriver's Avatar
Originally Posted by dcb View Post
Some hardware changes:
switched to the low power LCD from newhaven.
Max draw is 40ma vs 80ma = significantly less heat created.
Draw on low setting is 27ma vs 40. mid setting is 34ma vs 60ma
450 ohm backlight resistor instead of 82 ohm resistor for appropriate v-drop.
larger electrolytic capacitor (470uf instead of 330uf).
In another post you mentioned you switched to a 20Mhz xtal.
Is the code switched over to use the 20Mhz xtal vs the 16Mhz one?
I'm building my own from scratch and just want to 'load the code and go'.
thanks,
Dave
Edit: Found your post and indeed you switched to 20Mhz. Did the oscillator bypass caps have to change value when you went to 20Mhz?
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
