There are other methods. One is to laserprint onto special (or not so special) paper, then iron it onto a cleaned PCB to transfer the toner to the board. Soak in water to remove the paper, then etch the board. The toner is a etch stop.
I've never gotten good at that method. The nice thing about the photo method is it's easy to crank out another board, or many boards, with consistent quality.
I'm going to put a socket on my LCD instead of hard soldering it to my board. This will be a test bed and I suspect I'll need/want to take it apart and change component values.
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
