Originally Posted by mjspiess
I have the VSS wire from MPG directly to ECU wiring harness...so whatever sensor the ECU is using to get/deliver speed feedback.
Just recognized your username over at geometroforum. Your signal is reed switch generated. I wonder if you're suffering from contact bounce.
Dave
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
http://www.dschmidt.com/MPGuinoJBD.html
