Do you have a real temperature gauge? The factory one in the dash is useless.
With my Scangauge, I can see exactly what the water temperature is. Knowing that the cooling fan comes on at 206F, I try to keep max temp somewhere around 200. If it starts hitting the fan regularly, I open up the radiator a bit more. For a temporary fix, run the heater for a bit, as a secondary radiator.
