The question we should probably be asking is what flow rate do we need? And does it need to be variable flow or even intermittent? I'm thinking that if the pump is connected to the expander/motor it will automatically vary flow with rpm. If its pulley driven, the flow could be fine tuned by changing the pulleys.
