Old 07-07-2010, 03:42 PM   #109 (permalink)
Phantom
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Back to the air tools idea, if you get a tool that has a good amount of torque but is not fast enough that can be solved. The test with the die grinder was effectively running 1:1 being directly connected to the alternator. Now if the grinder is geared say a 2" pulley on the grinder and 1" on the alternator this places it at 1:2 so if the grinder is running at 200rpm the alternator will be at 400rpm.
An easy way to test what ratio would be needed it to use the sprocket from a bike so all that would need to be done is move the chain to the next gear to change the ratio till a suitable one is found.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
