Old 07-08-2010, 09:54 PM   #3 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I think a DIY hybrid is a great idea, and this implementation makes sense since you've already got the generator.
How are you going to convert 30A of 120VAC to... well, what voltage does your car run at? How large is this generator? Is it electric start? What will happen to the generator and its propane tank in a severe rear-end collision? Any idea how many lbs of propane it holds and how far that might take you?
Using a small engine to drive a rear wheel via a chain is the approach I'd like to take, but the generator is probably much easier to implement.
