Old 07-09-2010, 09:24 AM   #1 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Blocking the sun in sunroof
Our car has a so-called Solar Roof, a tinted glass that replces 2/3 of the roof:
Inside there are 3 panels that slide in the ceiling to block off the light.
This helps while driving, and makes it warmer in the winter. But on the top side those panels are black, so they get pretty hot in the summer. So in the spirit of Aerohead's Solar Sombrero, I glued aluminum foil to a piece of cardboard
and put it put under the solar roof.
This should reflect more heat and make it cooler inside. The panels can still slide closed. I'd like to glue alu foil directly to the panels, but getting to them isn't easy, plus I read that they are very fragile and outrageously expensive (US$400 per panel ), so I'm having second thoughts. The foil-on-cardboard is a cheap short-term solution until I get the courage to carefully fiddle with them.
ID:	6313   Click image for larger version
ID:	6314   Click image for larger version
ID:	6315   Click image for larger version
The Following 4 Users Say Thank You to Piwoslaw For This Useful Post:
j12piprius (08-04-2016), Joggernot (08-05-2016), mcrews (08-04-2016), SwamiSalami (08-04-2011)
