Old 07-09-2010, 10:39 AM   #942 (permalink)
Magister
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
"deprecated conversion from string constant to 'char*'" and others about string pointer come from c++ that does not understand pretty well the PSTR() macro, it's harmless.
The only ones you should take a look at are:
line 175: 'tankHold' may be used uninitialized in this function
and maybe
line 1374: comparison between signed and unsigned integer expressions
If you have a .hex you should be able to flash your chip, with either avrdude or avrstudio.
2013 Hyundai Sonata Hybrid
