Old 07-09-2010, 11:45 AM   #9 (permalink)
electrowizard
Hi saand, thank you for the reply
I will do both! Here are some images to feast on.
I haven't been able to post them due to my low post count.
The first is from my last failure. Ch1 is Vgs and Ch2 is current as measured by hall effect sensor. Conversion is (CH2-2.59)/0.0015625
The second is an earlier gate drive. Shows input and output of my 6A MIC4420 driver chip. This iteration had no gate resistor or TVS.
Third picture is the current state of the controller with some annotations.
I wish I could have made the image larger, it is tough to read. My apologies.
I was the one who said the case may not get hot; I said it because of the huge copper heatsink it is sitting on; if the thermal resistance is low enough it may be difficult to detect a temperature increase. Or so my train of thought goes
In the past I have driven a 1A motor and my 42 ohm precharge resistor simultaneously. Nothing got hot, I'm sure I could have run that load indefinitely.
I will try the light load again first, then move to something larger as you suggest.
Yep, inductive spike is accounted for and the pair of diodes work at last test.
As for having my mosfet backwards... please check the third picture and confirm my sanity
Yep, parts are correct. All the screwups are mine :P
Thanks again saand!
I will post back later this afternoon with the new results, hopefully a little success.
ID:	6319   Click image for larger version
ID:	6320   Click image for larger version
