Old 07-09-2010, 01:13 PM   #10 (permalink)
DonR
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
When people convert Jeeps to run on propane they generally use a heavier duty tank, like one off of a fork lift. I don't know if the fittings in the tank are the same as home tanks or not. They also mount them laying down instead of vertical.
I assume the efficency of an ICE running on propane increases with load, just like gasoline. Is there some electronic magic to make sure the generator only runs when it can run at max load?
