Old 07-10-2010, 01:24 AM   #131 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
solenoid with piston and reed valve
Originally Posted by LeakyIdeas View Post
drip a small amount of water into a tube at 500F
it expands to about 1600times it's volume,
heat a small rc motor to 500-600F and small amount of water is injected a few degrees ATDC, it will expand 1600 times and force piston down
if what is above is true
a small solenoid with a piston can be tasked to force "a small amount of water"
thru a reed valve into a chamber ON the hot exhaust , when that water converted to steam that could be routed to a diaphragm which would expand
with a rod to harness the movement, after the diaphragm moves up
it would expose a hole to
vent the steam, spring closes diaphragm to rest position , repeat .
if there was more energy in the diaphragm movement than needed to operate the solenoid
you would have something .
