Originally Posted by LSKLYNN
I prefer to carry a Supersoaker type watercannon filled with veg. oil. Roll your drivers window down slightly and place the tip of the oil gun out the window(careful not to look like you have a real weapon) and spray a little oil into the air passing by. Some will land on the tailgaters windshield and appear to be water drops. When enough oil causes the tailgater to activate their windshield washer, the oil will spread and create a sheen that the driver cannot see through - problem solved. Use with caution!
Umm....that is NOT ok
that can cause serious accidents, why not just slow down, stop on the side if you have to but DON'T do that !
