Old 04-07-2008, 03:21 PM   #55 (permalink)
AXMonster
British Ecomod Hypermiler
AXMonster's Avatar
The AXe - SOLD - '97 Citroen Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
Foci - '03 Ford Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
I think I know what I need to do now
Ideally the feed to the regulator should be 0v whan I want the alternator ro be producing no output.
I think it may be gatting some excitition from elsewhere i.e. picking up RF and then this voltage/current acts as the power to get the coils energised.
I need to ground the input to the regulator when not in use i.e. ground the yellow wire.
I think a relay that is grounded on the NC side and then fed the field voltage/idiot light voltage when activated should do the trick. So when not in use the alternator field windings are not fed any voltage and cannot 'pick up' any voltage!!
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
