Old 07-12-2010, 06:56 PM   #70 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
The CR-Z is no replacement for the Insight / CRX-HF
First-gen Insights aren't getting any newer, and I had been hopeful that the CR-Z might have potential as a replacement. The more I learn about the car, though, the more I realize it should never have been called CR-Z. What Honda have built is the S1500.
I was reading a review of the new CR-Z earlier, and there was an image that made my heart sink:
The CRX has good lines, attached flow all the way to the end of the hatch, and a small wake. The CR-Z forgoes this to accomodate rear seats in Japan and Europe. Honda won't tell us the Cd, but that particular feature has a pretty large impact.
There's also the matter of mass. Of course today's cars are heavier than those from 10 or 20 years ago, but the CR-Z is heavy even by 2011 standards. At 2654lbs, it's within 50lbs of the weight of a second-gen Insight, a Fit, and even a base model Civic.
In a simultaneous coast-down test, I would put money on a second-gen Insight over a CR-Z. I reckon they have the same mass, similar frontal area, and the CR-Z has a higher Cd.
Noted hypermiler Wayne Gerdes has one for a week, and he's getting 60's mpg. He came up with the following steady-state figures using cruise control and hyperinflated tires, though the data are tainted by electric assist at higher speeds:
* 45 mph - 58 mpg
* 50 mph - 53 mpg
* 55 mph - 49 mpg
* 60 mph - 46 mpg
* 65 mph - 43 mpg
* 70 mph - 38 mpg (2900RPM in 6th gear)
He also reported entering 6th gear at 28mph! Maybe you could find a much taller final drive in the junkyard to improve those figures.
Other problems reported: IMA has been set up to be inobtrusive. The brakes are intended to feel like those on a non-hybrid. This means blending regen with friction brakes, no matter how hard you press the pedal. It might be a simple matter to correct that with a brake pedal sensor fooler circuit, but you still wish they had set up the brakes for maximum regen from the factory.
So it's heavy for its size, it's less hybridlike with half the battery capacity of a first-gen Insight and hesitant regen, it's less aerodynamic than its predecessors, it's geared wrong, and the 1.5L engine is too large for the car. This vehicle has earned its lukewarm EPA ratings.
