Well, VSS won't cause a no-start, nor would one broken FI wire... Your problem is probably either unrelated to the install, or related to something you knocked loose while working on it.
"Acts like no fuel or spark..."
I think it's time for conventional diagnosis. Try starting fluid, then test for spark.
