Old 07-15-2010, 08:37 AM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
well, it is still possible to damage something if the wiring installation isn't done right (i.e. shorts or??), but the internal connections on the guino itself should not make enough load to damage most things on a car.
But you should actually check that you have a spark, and that it is injecting fuel and try to determine the exact reason your car isn't running. hook up an inductive timing light to a spark plug lead and see if it sparks (or hold a plug against the block where you can see the gap), take off the air cleaner housing and point a timing light at the tbi jet and see if you see fuel. You gotta do some troubleshooting instead of guessing.
I'm not sure about something in your first post:
"I checked the hacked connection to bypass the Injector resistor, connection still good. "
maybe it is a matter of terminology, but why bypass the injector resistor?
