Originally Posted by Pappnese
This tank (total 550 km (340 miles)) was mostly "semi-highway" (Norwegian highways: low speed, hills, crests and turns all the way) at an average speed of about 80 kph (50 mph), with some lower speeds and some, maybe 20 km (12 miles) of 110 kph (68 mph). In addition, it included 3 cold starts at about 20 degrees centigrade (~70 Fahrenheit) and maybe 15-20 minutes of city driving.
This tank gave a nice fuel consumption of 7.5 l/100 km (31.5 mpg) (measured by calculating fuel filled vs. corrected odometer reading) with the car loaded to 2450 kg (5400 lbs), which is actually a bit over maximum allowed total weight for the car (...)
Wow
![EEK!](/forum/images/smilies/eek.gif)
We use the same van at work to move from job to job on a construction site.
Transporting from 4 to 6 adults all the time, plus tools and supply.
Lots of idling, average speed for a 8 hour day must be below 40km/hour, including 20km of highway (120km/h) from our work site to the place I work for.
We are getting from 20 to 25L/100km.
I'm glad to see its only our fault if it gets that bad of a fuel consumption, because there is a lot of Caravan on the road nowadays.
