Old 07-15-2010, 09:59 PM   #26 (permalink)
Daox
Originally Posted by mwebb View Post
[COLOR="Blue"]on the vacuum gauge , wander is ok , normal even
if it had flutter the needle would be a blur of motion .
now
measure engine vacuum at 2k rpm hot
should be 2" above idle value
then WOT snap decel
vacuum should be around 24" as the engine slows down from peak RPM of the WOT snap
WOT = Wide Open Throttle
It is at 22" @ 2k rpm hot.
The WOT snap produced variable results, a quick snap only got it to 22". A rev got it to 24" and a good rev got it even higher. This engine isn't real responsive though, it revs up real slow.
I still have to check the fuel trims.
