Old 07-15-2010, 11:40 PM   #17 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Given the fact its a flathead engine, I do'nt know if that exhaust manifold is as bad as you think. It will probably flow more than those six Briggs & Stratton cylinders will put out. Once you get it running, try drilling a hole in the manifold and see how much back pressure is being generated. I'd bet it isn't much.
Go to a hot rod show and find a car with the old Ford flathead V-8 and see what headers they used.
Also, those "saddles" on the block might make it tough to put any halfway modern headers on it.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
