Originally Posted by ConnClark
Part load efficiency data is kind of hard to find.
But it stands to reason that it too will follow the basic trend of the Carnot efficiency equation of Nth= 1- (Tmin/Tmax)
Attached is results of an experiment of adding an intercooler to a turbocharged engine and keeping fueling the same.
and finally here is a link to a book on diesel engines. If you want to do a detailed analysis or partial analysis of how intake air temperature will effect things by plugging in numbers to equations this book will show you how.
http://www.dieselbookmarks.com/bombe...nce%20Book.zip
I can dig up some further studies and papers by NACA that show a similar trend if you like.
Edit: added the words "the same" after the word fueling
This looks correct to me, and verifies what I said.
Thank you.
