Old 07-16-2010, 07:53 PM   #40 (permalink)
Olympiadis
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
Originally Posted by Dr. Jerryrigger View Post
I have found it nearly impossible to get it to lock under 41, but when it does I can holed it down to 30.
That's the hysteresis for the TCC logic. There is often a minimum vehicle speed, RPM, coolant temp, max engine load, max TPS %, and a couple of qualifications timers for the lock function.
To unlock, basically the reverse is true with some additional factors such as delta-TPS, brake-pedal switch, park-neutral switch, delta-MAP, and of course the MPH hysteresis which gives the delay so you don't have constant locking and unlocking.
You can get better mileage by adjusting most of these calibrations.
