Old 07-17-2010, 05:08 PM   #34 (permalink)
aerohead
hub
Originally Posted by NachtRitter View Post
Here you go:
Very interesting approach... Those front skirts also look like they are attached to the hub (or some part of the spindle assembly) so that they can turne as the wheels are steered... I'd also guess there is little or no suspension to worry about.
If I had to guess,I would think that the spindle is stepped and that after the section for the castelated pre-load nut and cotter-pin,there is a second section,perhaps with a square section to which the outer fender support is attached and locked in where it cannot dance around.
Thanks again for photos!
