Your correct that a propane setup for a small engine requires 2 regs. One reduces tank pressure to an intermediate of 1 or 2 bar. The other decides how much gas to send to the mixer (carb) depending on intake manifold vacuum (ie demand). Some demand regs will work at tank pressure. Others not.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
