Old 07-18-2010, 10:11 PM   #174 (permalink)
Phantom
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Where might one get a 1000:1 reduction gearbox inexpensively that will handle the power?
Built one.
If you are turning an alt you are not going to need it to take a lot of power just have the first stage bearings able to hold the RPMs like ones in an engine, turbo, or supercharger.
Starting RPM 200,000
First gear set (pullies) 10" to 1" Ending rpm 20,000
Second gear set (running from the spindle of the 1") 10" to 1 ending RPM 2,000
I think 2,000 RPM would be fine to use to turn an alternator.
Also the turbo will not be turning that fast at idle to 2500RPM and can be controlled with a waste gate (or electric exhaust cut out) that is set to open when the pressure or RPM of the turbo reaches X.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
