Old 07-19-2010, 09:00 AM   #3562 (permalink)
voltmatic automaton
diode and resistor combo
what kind of values do you think would be good for the diode and resistor combination.
Now that i made the changes to the gate resistors the gate resistance is 30 ohms or so (30.5 i think)
so aside from resitor values what kind of diode should i get?
and would i just daisy chain these parts together? seems like a lot of parts just twisted and soldered together....not that i'm not good with that....that describes most of the car
i believe someone on the diyEC forum described the parallel dode and resistor setup you mentioned for this project.
thanks for your help!!
