Old 07-19-2010, 02:10 PM   #1 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
variable speed centrifuge plans............
This is just in the planning stage, drawing is crude and not demensionally correct but here it is:
I looked at the grinder motor I have and it still works, rpm is, guessing, about 1000 on the lowest setting before it starts pulsing. I have some pulleys but not sure diameter or shaft size. I want to make the table from 2" drilled square tubing, will be welded on the corners and will be easy to bolt the other parts to. I have a source for used atf, free, and want to clean it for the 93 truck and Rabbit. I spend close to 6000.00 a year now on fuel and want to take a bite out of it. I can get a rotor, new, from RPC, for 250.00 and think I will be able to get the other parts for free because I have most of it already. Might cost 350.00 when all said and done.
---rotor-12"--------
Motor RPM- 3400,
Drive pulley diameter(dpd)- 6,
Driven- 3
RPM- 6800 (7880g)
dpd- 5
rpm-5664 (5470g)
dpd- 4.5
rpm- 5100 (4430g)
dpd- 4
rpm- 4532 (3500g)
I'm open to ideas, comments, suggestions............
