Originally Posted by JeepNmpg2
See, roof racks can be good for mpg.
You'll probably want to tuft test it eventually to find out where you have attached flow and where your angles are too steep / abrupt. I think you'll have flow detachment at the sudden transition from square to angled, especially near the top corners. But if you're seeing an mpg improvement, it's obviously better than stock.
